Airmote configuration settings,
Would be good to be able to configure the airmote to individual preferences
For example to be able to adjust the speed and sensitivity of it as currently the movement feels to fast for me which makes it hard to both scroll and target precisely for clicking on something,
Also be able to custom And use the OK button for clicks, the OK button just feels more intuitive as that’s already the button used to confirm commands, it being located on the centre of the remote also helps, for those that are happy and are used to the current set up they can still leave it as it is, what do others think?
