Navitech Schwarz Robuste Kamera für Harte Beanspruchung. Kompatibel mit Phillips Picopix Max Navitech Schwarz Robuste Kamera für Harte: Amazon.de: Kamera
They are starting to appear
Unfortunately, it is a universal carrying case.
Everything you put in it can move around freely, there is no separation inside.
I will not trust this type of product
Very good job !
Thank you for sharing.
PS : It’s 17.7€ now ^^
But 14.2€ here ==> https://www.amazon.fr/Accu-Case-Mini-boîtier-daccessoires/dp/B00G4902FY
They adapts prices relative to offer and demand
Got my new case for the PPM. Everything fits except the original tripod which I don’t use.
Case: https://a.aliexpress.com/_dXOjsRV
6ft 100w USB-C cable: https://www.amazon.ca/dp/B07XFC86YT/ref=cm_sw_r_cp_api_i_pEhuEbM9246FX
Tripod: https://www.amazon.ca/dp/B00WWNFRD8/ref=cm_sw_r_cp_api_i_VEhuEb9C8T527
Portable projector screen: https://www.amazon.ca/dp/B07QTFRT4N/ref=cm_sw_r_cp_apip_Rg2Sh4hI1Yg1N
Perhaps this could be merged with this thread:
Done
Seems to be a good choice
I got this one from Amazon. Works pretty well for me. Was able to get everything in it. https://www.amazon.com/gp/product/B00RMGXZTS/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Where can I buy this ?
Which model - hybrid? and what dimensions? @Adjuro
Also, did you insert the Philips logo yourself or have that custom made?
When you buy a magazine.
You can get a bag that is just the right size for your projector.
[MonoMax(モノマックス) 2020年 5月号 | |本 | 通販 | Amazon]
SHELL-CASE Standard 300™ Model 320 Case (275 x 215 x 95 mm)
So it is an Hybrid 320.Got it from this web site
Standard 300™ Model 320 | Flightcases International A/S | Flightcases International A/S and I added the pluck foam option.
Custom made myself, there is slot to put whatever you want.
Hey DonJazz, how’s this case working out for you? I see your photos on AliExpress, the Zmi powerbank doesn’t seem to have a place to go, other then loose on top of the projector, is that right?
