Hi all. Had anyone had this issue. See pic below. The bottom left has a shadow on the edge of the image.
Many thanks in advance.
Have you contacted support?
Same same for me.
No not yet? Have you… I’m not sure who/where to contact? Looking like it might be an issue for a few people. I started a separate topic when I noticed the issue.
Hope it can be resolved!
Same here at the top right. Thought it could be an issue with the projection angle which is very extreme in my case…
Mine is all around the pic. Projector is not tilted in any ways but on flat surface. This is happening both in hdmi mode and normal start screen.
I, like many, have a bit of this on the top. If you display an all black screen at close distance you will see that it’s actually darker there. I believe this is glue that has overrun slightly during the optical assembly process. You could try swapping it out but it’s a bit of a lottery
