A stupid question but just want to be clear that you are connecting the cable to the right USB C port on the PPMax, correct? Only the right most USB C port is for charging.
Just adding me to the list that doesnāt get HyperJuice (PD 15V, 3A) to charge my PPM
. Tested with both the boxed cable as well as an other ācertifiedā cable. Both cables working with the boxed charger.
I do have the HyperJuice as well⦠really like the size⦠but no charging of the PPM⦠tested many cables⦠a satechi charger⦠the 75 as well as the 108w version charges the PPM just fine.
