If you paired the remote with the PPM in Bluetooth, only the power on/off command need IR.
All other commands will be sent by Bluetooth so no need to point at the PPM anymore.
As @Morganjp said, you can find the informations here :
Hi, thanks for your response, it’s fun
I found this app that works great as a touchscreen:
Really easy to connect.
I´m backer #109* and i haven’t yet get mine PPM
I use now my Nebula Capsule I and same problem with IR it’s only in the back. So i use everytime remote app, it’s work like charm and input also mouse working nice. My vote for the program.
in fact, i do a mistake because you have the capability to connect the remote in bluetooth
, it’s extra
So does the remote control work with bt? …or only AirMouse?
After all, it would be good if all the buttons on the remote control, including the power, operate via BT.
Can you test this function - cover the IR receiver.
Power = Only IR (Cause when the device is off, no Bluetooth driver is loaded/active of course)
Interesting find. I had been looking for an app like this for some time now but never ran across a working one. Did you actually get this writing with a PPM, or any other devices for that matter?
So far, I can pair my phone as “input device” with the left-right half arrows device type icon ( like the AirMote has). However, I cannot go beyond pairing and actually connect. Tried it in normal and in Los energy mode on the phone, same results.
I sent a message to the app developer, might be a problem with Android 10 on my phone.
I’ll also test this with some other raspbian and Ubuntu devices I have that will give me more troubleshooting info to work with.
i tested it and PPM can be power with the remote without point the remote on the IR.
Maybe just due to the infrared reflection of an wall etc? Or did you 100% covered the IR-sender?
@Philips_Support_P Hope you can update the iOS app for picopix max. It says the latest update was 4 years ago. Perfect time to update it now. Thanks!
SchmuFoo, i do a mistake and you’re right ! I confuse speed and precipitation
It’s by the previous company which had the projector license, not by us.
We’ll make an app too, but only after 2-3 months when the internal software is completed.
Are you guys at Philips planning to add a working remote app like the “Nebula” one?
i found one on app store but seems like it is not being updated since ever!
This was suggested a few times before, this is what the development team had to say about it:
Thanks! Anything working at the moment? Appreciate your help
Not that I know, like they said they want to complete the internal software first before starting on external apps.
I’ve moved your topic in the main one.
You can vote here to add your voice (if not yet done)
Ever since my laptop keyboard went dead, I used the Unified Remote app on my phone, to type and control my laptop. Despite the strangeness to use my phone to input/control my laptop, daily input/control tasks are just as easy.
The interface in the phone is very easy to get used to.
The keyboard is the default keyboard the phone uses, so typing is pretty easy.
There are also other remote interface for Media player, Screen mirroring, touchpad, numberpad. Which I find really user-friendly for most tasks
It is not easy too use the touchpad on the PPM letter by letter, if we can go so like how we swipe around on the phone, it will be awesome.
If PPM has similar functions as Unified Remote, allowing us to use our mobile phone as keyboard/touchpad etc as input, it will provide much convenience.
I’m not technically inclined, in Windows, a Unified Remote software also needs to be installed and paired for the very first time use. Not use if it is possible doing the same in Android.
