Everything is showing as double
My Picopix is showing like split images.
I turned on and off autofocus, what ever i do it stays like this.
Manual focus also does not help?
No manual focus didn’t work. However i kept a paper in the front then moved it forward and backward when it was setting autofocus it took many attempts when we get till long adjusting sounds then pressed autofocus it worked, but the problem is after restart same issue and i had to do same steps to resolve.
I had a similar looking problem, as if there are two misaligned images. There’s a similar thread: ‘blurry, double’ or some such name.
I couldn’t fix the issue so now my projector is currently being inspected by Support. Will keep you posted on the outcome. I’m not sure this will be fast, but I’m hopeful
Oh I see let me know the outcome
Hi Vamsi, great news! Today I received a replacement projector. I haven’t turned it on yet though as I’ve been sent the wrong plug adapter set (I need the AU adapter, but they sent me the UK and EU adapters). Just wanted to let you know the status. Hopefully you are able to get your projector sorted
