I followed the prompts to update to new firmware, and it all seemed to be going ok. I left it alone, but when i returned, the device was off and wouldn’t power on.
The LED is flashing red/blue and it has been doing that for 2 days.
Try using the actual cable and power supply thing that came with the PicoPix. Using other power supply sources like MacBook charger might cause this problem
Thanks Mifuad. That solved the problem.
