Regarding audio lag for Bluetooth audio devices, could you test again but this time, remove a battery from the AirMote once you have started the movie. Wait a few minutes and see if the audio eventually sync up.
Thanks.
Thanks.
I’m using this Bluetooth keyboard with trackpad. It works great! I don’t even use the AirMote anymore.
Brief update from Spain… I just got mine!!! So excited to update it and start using it. @Philips_Support_N packaging is stunning!!! Congratulations to the team!
Will share further pictures later in the week
Here’s a different kind of unboxing pic from a fellow Finn!
Don’t worry, I didn’t forget to check for the remote!
Nice one! Unboxing by brute force, the Finnish way
My tracking number shows up as registered in the LostNord app at least, and also the annoying status “recipient at residential address”. That’s partially true even though this is addressed to my company (at the same address). LostNord is one of those companies that isn’t very keen on actually delivering to residential addresses, they just want to drop the parcels off at a pickup point. We’ll see, it still says “deliver to: door”. Whos door is currently not known
Nice shot!
this is a transportation issue. Can you check if the touchpad works? We will need to open a case with DHL. Can you send us an email with pictures of the product and the packaging ? Also, please check if the product is fully functioning.
Packing looked in good condition but I’ll email photos.
Hi! Would you be so kind to tell me the exact dimensions of the shipping box? In my case, it seems DHL has refused to send the package to a packstation because of the size, so it would be of great help to have this information. Thank you in advance!!!
Sure
22cm x 18cm x 12cm
Weight 2.04kg as written on the box
Hi, maybe they said the reason is size because it’s the only reason their system allows to inform. But from my experience they often refuse to use packstation due to battery. And they won’t put there anything that has more than four AA batteries capacity (I’m not sure but it looks like it)
Hi @Philips_Support_N, I emailed pictures as requested and got this reply wishing me a great experience when I have received a product that has a major visual flaw to the product?
sorry about this ahah, I just sent it back to the chief of Support
Today I finally got my device - I got the tracking number on April 10, so it took a bit over 3 weeks for it to arrive after that.
Initial thoughts:
Anyway, great product so far and thanks to the entire team that I’m sure have worked very hard to get this product into the hands of backers and customers!
Got mine today, UK, Backerkit no 77xx.
Well put together package, but bit deflated really, after so many months wait.
Projector very noisy, not very bright, video playback not smooth, dull colours.
Software update not making a difference. Will give another try but likely sending back.
Might be the high expectations, but definitely not worth the money and the agony of so many months waiting.
