Here is my first impression. After a very long wait, ordered back in Oct 19, #17181, I just received it on 22 Jun 20. I have been chasing for this unit and numerous emails to and fro with the initial issue with my order than the issue with the DHL tracking. It took like ages (3 weeks!!!) from Hong Kong to reach Singapore!!!
I have done my research on the unit from this website as well as Youtube so starting using it was not as daunting. Wifi connection to 5GHz was unsuccessful but manage to hook up with my 2.4GHz and software update was a breeze. Pairing of the mouse also did not face any issue.
I watched Netflix as well as Youtube (pre-installed) without any issue. Someone said I need to delete the pre-installed Youtube and install it again from Aptoid? Is this correct, why do I have to do it?
Auto focus and keystone adjustment works like a charm however I do notice some slight distortion on the top left and right side of the frame, might do calibration later but I can live with it now.
I have sideloaded 4 apps and they all been working perfectly on PPX!!!
Anyone using Kodi on PPX, any issue???
I managed to pair the audio to my LG soundbar using BT and did not notice any lag in audio at all. Pretty happy with that.
Overall, it meets most of my expectation except:-
- Better quality tripod would be welcomed
- Luminated remote would be a godsend!
- While watching Netflix, the preinstalled app does not allow me to skip intro like when I was using my Mi Box S.
- While I am watching Netflix, I use to be able to pause quickly (using my Mi Box S) by pressing the OK on my remote but it does not work here. I need to press on the Arrow button then scroll over to the play icon on the screen in order to pause it. Is that the only way to do that???
- Like many, I try to charge PPX using my external powerbank and it does not work too due to voltage required.
- I hope future software update can allow for horizontal keystone correction as promised.
Very first impression - it is much heavier than I thought! Size is pretty good. Someone is good at tetris, because I’m not sure how you crammed all that stuff into the box. The carrying pouch is nice, gonna use it for storage. The tripod is actually quite decent, but I do wish you could lock the legs so it could stand on a smaller surface. The airmote works really well, that mouse feature surely is magic
