Note, your projector already has app usage data from the past few months, so don’t be surprised if the order of the apps changes as soon as you install this update. Privacy note: all this data is device-local only, it is never sent anywhere else.
This feature is an offshoot from our recent work to bring “cloud apps” i.e. Philips-provided apps that you can install right from the Home Screen. Let us know your thoughts. Thanks!
I can remove the hearts by pressing [menu] and selecting [favorite]
But after turning the projector off and turning it on again the hearts are back and still in the wrong position (not before the other apps)
I can only clear the favorites (hearts) in the hidden android menu by [clear data] in the screeneo launcher app
