Did format an USB stick on the projector and it got a FAT32 format, is there a possibility to support any other file system format to handle bigger file sizes (Over 4GB)? And an option to select that when you do format an USB Stick or MicroSD card on the projector?
Did try to format on Mac for a better file system, but it was not readable by the projector! Maybe NTFS would work?
Issue is to easily transfer media files from network / NAS / PC / Mac to the projectors internal storage or Micro SD card used by projector storage! Files mostly over 4GB in size.
(Maybe file manager in projector need an update!)
Any ideas?
