Have you already done the troubleshooting according to the instructions here? If not, please do that and report your results. If you already have completed that and nothing helped, please contact support either by email support@screeneo.com or via https://support.screeneo.com (top right corner of page). Remember to include your results from the troubleshooting, it will make the whole process smoother.
like i wrote in my first post, leds show the correspondings colors but the led lightsource never turns itself on and is apparently a known manufacturing issue on thoose units. I already wrote support an mail and wait for response. I have no real hopes of a quick turn around since well we are in May already for something that was suppose to be here half a year ago.
Anyways at least i received a broken unit
some are still waiting to receive anything and with the way 2020 has rode us all a broken promise is a nuisance but not the end of the world.
You can’t infer current and future results from recent or past results, as we have learned a lot from the road so far, have overcome many issues, including lockdowns and temporary factory closures, shipping nightmares (still struggling with those a bit) and so forth. We are producing them and each unit with an issue leads to the next batches being better. So you might get an even better unit, sooner than the 5-8 month wait so far.
? get a better unit? Every single damn unit should be pristine. We paid pristine money for that and therefore every single unit should be pristine. That the hole production lacks QA left and right is no secret and is actually a sad state.
I don’t care about things that are out of the hands of Screneo, like shipping hassles or global pandemics. But quality of their products is 110% their fault and their responsebility and no one elses. No one forced them to send and not recall faulty units. They let the customer sort this stuff out with is a pretty shitty move.
I feel for you, receiving a faulty projector after waiting for this long is a bummer, no doubt. But good QC doesn’t mean that every unit gets tested, just that a sample big enough passes the quality control. There will inevitably be some faulty units that slip through. I’ve had experiences like yours with other big brand products.
If you are interested, the QC process is explained in more detail in this post: General info about shipment and manufacturing
If you have sent your complaint through the right channels, you will get a working projector in the end.
Its clear to me how the QA process works and how PR processes work.
i’m sure everyone followed the process so faar the ups and downs and the issues and non issues.
Anyways, i contacted support and lets see how long all of this will take.
I have sent my report 10 days ago and no reply. I am wondering what is happening.
Here a forum version:
Check Power Adapter and USB cable
Are you pressing and holding the power button (on the projector or the remote) for a few seconds? Yes
Are you using the supplied power adapter and USB-C cable? Yes
Do you see red/blue flashing LED on plugging in the charger? This means the power adapter you’ve connected is not supported. Please use the supplied power adapter.
If you’re using the supplied adapter and cable, continue to the next section.
Check battery charge status
Make sure the projector is powered OFF.
Connect the power adapter to the projector. Make sure you plug it into the right side USB-C port (charging port), not the left side (video port)!
Does the LED turn red? If yes, let it charge for 3 hours until the LED turns blue. Then unplug it, and power it on. Does it work? Yes
If the LED doesn’t light up at all, check that:
the adapter is receiving power from the wall socket.
do you have another USB-C device? Can the PicoPix adapter charge that device? If not, the adapter may be faulty.
If the LED lights up blue, it means the battery is fully charged. Continue to next section.
Check display problems
If your projector can turn on but doesn’t display any picture, check this as you power on the projector:
Do you see the white Philips logo startup screen? No
if yes, but there is no picture afterwards, check that all cables (HDMI / USB-C) are unplugged.
does pressing the home button on the remote or touchpad causes the home screen to appear? No
does pressing the autofocus button on the remote show the focusing screen? No
Does the projector power off shortly after showing the home screen? It could be a thermal shutdown. check next section.
Thermal shutdown
Do you hear the fan spinning up when you power on the projector? Yes
Do you have at least 30 cm free space on all sides of the projector to allow free movement of air? Ye
What is the altitude of your city? (the atmosphere might be thin!) under water (Netherlands)
What is the room temperature where you’re using the projector? (20 degrees)
Hope to get some feedback.
Best,
Georges
After the initial contact and refering to answere tons of completly stupid unrelated “throubleshooting” questions radio silence.
Its pretty clear that the product is broken if the led engine does not start up at all after turning the max on. But apparently to be 100% clear that the damn thing is broken and does not turn on they send you on a funny generic support ride. I am still missing the question if i am a terrorist or some bs when the max just does not turn on and when its clear already that theya are fully aware of the damn issues of thoose batches the’ve send out and since then apparently fixed that too short cable and still do odd ridiculous support dances for them to take their broken stuff back and investigate themself whats broken and replace it with a working unit.
Basic customer support would be too much to ask. Instead lets put more silly burden on the customer who already paid in full! What did you eat for breakfast? Is your mother name Karen? Do you own a pink dogwhistle. Does the broken projector start working when you close your eyes and put your fingers in your ears?
We’ll get back to you to see if we can find some more bs to throw at you at a later time, stay tuned.
@Philips_Support_T Could you please stop the radio silence and also quit referring to covid issues. In my view the only issue right now is that you are not being transparent on what’s happening. I cannot imagine that it can take over a week to come back after the form has been submitted. Or maybe you should consider shipping those new wires for the led and make a service bulletin… Philips should have contractors in every country to fix their products…
Dear Jukka, your defective product has to be picked up first and we will send you the shipping documents within this week.
Thank you. Just wondering the latest update email saying that the latest firmware “• fixes a rare issue where the light engine might not power on at all.” Is there a way to know if the light source not turning on is a HW or SW issue? ping @PhilipsEngineering
Hi, The light engine not turning on is a software issue if and only if it was working before, and after update to v1.1.00 or v1.1.01, does not work anymore (not even the Philips logo will come on screen.).
For all other cases, it is a hardware defect. Anyone who is experiencing this out-of-the-box, has a defective hardware.
PS: If the Philips logo comes, but the home screen doesn’t —> it is a different software issue that can be solved by performing a restore by cable.
Good to know - nothing came up ever so it’s a faulty device.
I have the feeling Philips didn’t expect it would have a big sale. Now they are under powered relying on the community which can help only within their powers. A broken bulb / short wire is a factory issue. Since the only thing I saw was a simple excel sheet I have the feeling that the supply chain management system is very difficult to control.
Really hope Philips gets this on track. Probably a lot of work. So good luck @Philips_Support_T hope it gets back on track soon. Would really love to start the Sopranos on the picopix
@Philips_Support_P @Philips_Support_T
Ticket #19138
Could use some help.
I have had no reaction after the first generic response
Ticket #21056
My Bulb is as dead as Goerges one.
hi @Philips_Support_P I’ve been waiting for my label for the return of my defective unit for more than 2 weeks now. Any chance we can chase? Request id: 19319
Hi @Georges1 @Alessandro_Giordo Our after-sales team should have already responded to your tickets by now.
@macish your ticket is escalated, a response should be sent asap.
thnx… lets see how things work out.
I received my unit after waiting months (6 months late) at the beginning of May. It was dead on arrival, looks like it powers up with the fan running and battery status LED coming on but no picture coming from the lens.
From what i have read on here you have a known issue with internal cabling being at worst too short or at best badly toleranced and being under excessive strain that will cause an early life failure or probably in my case a failure induced in shipping (I am assuming you did test all the units before shipping ? You did test them ? didn’t you ?).
You should know all the serial number that issue applies to and recall and replace all the units that this design failure. If you are luck and the unit has been sent has this latent design issue but it has not not initially caused you problems then i would be fairly confident that the majority of these units will develop a fault at a later date.
I should say that these views are based on my 23 years of experience of design electronics profesionaly for aerospace applications. I have seen a lot of NPI (new product introduction) problems in my time and they never just self resolve !!
I raise a support request on the 7th May and have heard nothing back (other than an automated trouble shooting check list thing, some what unnecessary as i gave all the details on my initial email).
3 week have now passed and I am now any further forward a resolution and have had no contact from Phillips. I do hate when companies just ignore you with no communications.
So Philips what happening ? are you going to reply to me ? Are you going to replace my unit ? when will i get my replacement ? Are you going to send us early backers replacement units before sending known good units to later backers ? How may more months or years are we going to wait ? Or will you do the cop out that I have seen before with other kickstarters that can’t deliver and refund me after using my money as interested free with no product or interest payment ?
