Shipping to Europe
Neither has the rest of us in the EU. Please be patient - we should (hopefully) receive the tracking numbers in the next 24 hours :slight_smile:
Yes we are still working on the file cause we do need to enter manually each and every backerkit ID to match each backer. Backerkit asked to have a proper CSV with infos that are not related to DHL in order to import it in the database. a bit long…
Yes @Philips_Support_N I’m aware it’s a real pain.
in another crowdfunding campaign that I supported with numerous backers, they had almost full time people on it !
You should already have a list of iggo to backerkit id’s - its just a simple excel vlookup to match them.
If you need help - just buzz
Thanks a lot Nono for giving us all those updates.
welcome!
This question was already answered by @Philips_Support_N.
Shipment is based on the Indigogo Contribution ID
Sounds like a fun task :joy:, thanks guys! Do you still plan on providing tracking numbers today?
Excellent update, thank you for sharing! All those projectors on their way to Europe.
Must say that Indiegogo as a crowdfunding platform has a long way to go to actually support the creators past the money funding phase:
  • Their comment section should be accompanied with a search box and chatbot
  • They should give selected partner such as backerkit full API access to create a seamless transition from confirmed order to DHL tracking code sent. This would enable features such as exporting the backerlist in correct CSV format to the courier (DHL/UPS/FedEx) and importing the tracking numbers
  • They should offer an Indiegogo run warehouse in Europe, USA and Shenzhen to handle the logistics
Now they are taking the cherries from the cake in terms of provision from collected total sum and at least partly responsible for making almost every crowdfunding campaign a mess to deliver. Have sent this feedback for Indiegogo as well.
I’m working with automation of stuff like this on an everyday basis - you guys should’ve just asked for help :slight_smile:
It’s called Formpipe Lasernet
Is this the warehouse in Europe?
It could probably be done with a Perl one-liner. Or a juicy sed/awk-command-line.
Si il faut nous donner les bon de DHL, cela veut dire que les ppm sont déjà chez DHL en livraison ?
oui bien sur ils sont deja au warehouse de DHL
En Allemagne ou à Hong Kong ?
My backerID number is way above the amount of ppm’s sent this week (75XX) and that is okay, but I am truly excited for all you fellow Europeans who are going to receive it in the coming days. :smiley:
Du coup ils sont peut être déjà en train d’être livré en attendant que vous mettez le fichier excel a backerkit ?
Ou la livraison commence quand vous nous avez donné les codes ?
La livraison n’attends pas le partage des codes mais c’est sûr qu’ils ne sont pas déjà livrés, il va falloir du temps pour les envoyer dans un entrepôt en Allemagne d’abord puis les dispatcher à travers l’Europe.
si j’ai bien compris ils sont déjà en Allemagne ?
Pas sûr, soit à l’entrepôt à HK en attente de départ, soit déjà arrivés en Allemagne, soit dans l’avion.
