most likely cleared for import into SG. physical product should be still in HK.
For Singapore specific apps, so far I have tested Singtel CAST and meWATCH. Both partially works. Although meWATCH will complain that it needs Google Services, just click through it and I was able to watch live TV and some shows.
Also tested StarHub Go. Cannot launch the app. Crashes upon launch.
What is the process to pay for GST in this case, looks like the device is already Customs cleared. Will it be handled by DHL ?
Thank you William, u used aptoid or manually install by searching for apk?
I understand is pay at point of delivery from past experience
SG shore now according to tracking
I use the Aptoide. If you find out other APKs that works, kindly share here. Thanks.
I think you will get it tomorrow. DHL is very fast once it arrives here.
Quick tip once you get it:
- Connect to charger.
- Turn on Bluetooth and pair the AirMote.
- Connect to WiFi - preferably 5Ghz band and not the 2.4GHz one.
- Check regional settings and check that the date/time is correctly sync via WiFi.
- Go to Settings and update to latest firmware.
Do offline update if unable to download over the air update.
See this post for other getting started stuff.
Enjoy your new toy!
Forgot to mention, use Energy Saving or Normal mode for better colours. Presentation mode doesnât have good colours.
Awesome. Canât wait
I would urge you to report the working apps in the thread for that, to help others looking for this information. Itâs here: Working Apps List discussion, feeds the Working Apps List
Thanks for the reminder. I am just too lazy to gather all the parameters for reporting. Besides, these are really Singapore specific apps that I really donât think the rest of the world will be very interested in. But you are right - I will try to update in that post if I am able to get those details. Thanks again.
Perfect, that is convenient as compared to what EU folks have to do. Thanks !!
I just received an SMS from DHL to pay the import tax online. Youâll likely receive the same soon.
ITâS HERE BOYSSSS, ITâS BEEN A LOOOONG WAIT.
Do you have to pre-charge it for 8 hours before use? Or can you use it immediately after taking it out from the box and connecting it to the charger?
Sorry, I donât know the official recommendation for this.
For me, I did not wait. I connected it to the charger and immediately played with it.
Nice! My last update was 9:40pm at Singapore sorting facility. Whatâs your status now? How much is the tax to pay?
I ordered three sets, costs me about $60 for the tax. They mentioned itâll be delivered by EOD on Monday!
