I would love it if I could add shortcuts to webpages to the ppx home screen.
That appears to be inaccurate as others managed to install android tv
Hello, is there any news regarding a future software update for the PicoPix Max ?
As things are, we wonât get anything, no fixes, no improvements of any kind. In short we go dupped into financing the following model without taking in the benefits. End of the day, device will continue to work as is, until it breaks. Too many headaches? Give up. Get a Chromecast with Google TV.
It is a legal/business issue, not a technical one.
We are working actively on the Home Screen refresh. A beta is already out and the first public release should be within a few weeks.
Will the âhidden menuâ still be accessible via the new launcher?
I would still love to have a âForce stopâ option in the context menu of apps in the launcher (in addition to the current âOpenâ and âUninstallâ), so I can close and restart apps without going into the hidden menu and finding the app in the list.
Hello @_fov good suggestion, we will add a âForce Stopâ option to the context menu!
On a slightly off-topic note, I can read the beta-launch but I can not post or reply there. That makes it harder to give feedback.
With the new beta launcher even with RC2 going back from an app or settings menu does not take back to the home screen but just see a blank screen. Have to press Home to get to the home screen
Uninstalling an app from its context menu leaves the icon in the launcher until the launcher is scrolled.
Apps in the launcher can not be opened by pointing an clicking; when clicking with the (top left) pointer click, the app icon that currently has the focus is launched instead of the app underneath the pointer.
Another topic with the new launcher, Iâm missing the time left estimation running on battery.
Overall, I like the new look & feel ![]()
Dear PicoPix Max users,
Great news: we have rolled out the Home Screen Launcher V2 to everyone! Read details here on whatâs new. In a nutshell: better performance and stability.
Over the next few weeks we will release further updates. We are aware of certain missing features in this initial rollout like favourite apps and battery time remaining. We are working to bring those back as soon as we can.
Would like to be able to hide (for me) âuselessâ apps like File manager and Media Center. Would like battery percentage.
I agree with you, the ability to hide some unused apps would be great.
I have installed version 2.3.4 and there is still the screeneo launcher visible on the dashboard. With the previous version of the launcher (v1), it was hidden. I believe this is a bug, correct ?
In fact the previous launcher will be removed when we will push the new launcher by FOTA update. Please remove the 2.2.4 APK and app from your Max, restart it and you should see a pop up appearing asking you to update it
I noticed in the new launcher, the apps cannot be clicked with the mouse pointer anymore, only with the okay button. Clicking with the pointer does the same as okay button it seems (so if you already navigated to another app, THAT app will open, not the one youâre pointing and clicking with the mouse pointer). Probably you know this already but I just wanted to give you notice of this.
With version 2.3.5, clicking apps with the mouse pointer seems to be fixed (jaj!). Unfortunately it seems to have made navigating the apps with the up/down/left/right buttons a lot worse. When the view moves up or down, the selection is reset to the app the mousepointer was on when it was last active.
Steps to reproduce:
- Have more than 12 apps installed
- Scroll all the way down the the apps
- Activate the pointer and hover over the app in the bottom left (keep the pointer here)
- Now use the up & right buttons to scroll up and to the right (deactivating the pointer)
When reaching the top row of icons and the icons have scrolled up, the app selection is reset to the lower left app icon. As a result, the icons scroll back down.
Yes, I just saw strange behavior too. Pressing the up arrow a few times, the active tile mostly goes up, but sometimes down. And sometimes skips and moves 2 places, also sideways and down btw. Something is not right.
Hello, we are aware of the issues with mouse and D-pad navigation and a fix will be out tomorrow. Sorry for the inconvenience!
