its easy to find chargers with the required output voltage + current (15V) needed for the PP Max.
The little problem with all of them i know them is: You get the 15V output requestet by the PP Max only when you have much more then 12V Battery Voltage (Datasheet say 24V) .
They are looking like this when you want to install it permenently: https://www.amazon.de/Thlevel-Ladegerät-Fahrzeuge-Motorrad-Wohnwagen-Blue/dp/B08YN9812H?th=1
Problem is: I didnt find one of them with a so called “boost converter”, so can makes 15V out of 12V…
Does sombody know such an product ?
LinkOn 63W Car Charger With 45W USB-C PD3.0 PPS and 18W USB-A QC3.0 Compatible with MacBook Pro Chromebook iPhone Xs/Max/XR/X/8 iPad Pro/Air 2/Mini, Samsung Galaxy S9/S10/S20 Pixel Nexus Huawei https://www.amazon.co.uk/dp/B077ZRBPNB/ref=cm_sw_r_cp_api_glt_fabc_7P2HDY74XASWVPS2JAAF?_encoding=UTF8&psc=1
will do the trick
Thanks for you Input.
I got the right Buzzwords from you: “Car” or “Auto” + “USB C PD3.0”
So i ordered this for 13€ in Germany: https://www.amazon.de/LinkOn-Ladegerät-Delivery-Qualcomm-Nintendo/dp/B077ZRBPNB?th=1
Alternative (27€): https://www.amazon.de/LinkOn-Ladegerät-Delivery-Qualcomm-Nintendo/dp/B077ZRBPNB?th=1
I will give updated Feedback
