@Philips_Support_P is it possible to do horizontal auto keystone correction by using the onboard camera to recognise horizontal features in a room?
Any update on the progress?
I have had the same issue as most in here (not a square image) and I just thought it was ānormalā but I have now received my second pico today (bought one for my parents) and it does not have this issue. I believe it is a manufacturing defect in the original unit as no matter the surface the pico is projecting on, it never produces a square image - always a trapezium. The focusing is also far louder in the original.
Please tell me what comparison pics you would like me to upload to further demonstrate the issue.
Someone from Screeneo really should make clear if itās factory issue and reason for replacement or itās fixable by FW. Iām also facing this issue and I thought itās normal and Iām not happy with it
All of them! Well, those you consider showing enough to display the difference between the two devices would be really helpful.
The issue that this thread is addressing is not about correct rectangular projection, this is about linearity distortion that happens even if you manually adjust the image correctly with 4-corner adjustment.
The image does not compensate for the angle the projector is at relative to the projection and distorts the image (one side stretched, the other compressed).
Your issue sounds different and there are threads of users mentioning that issue.
Thatās the distorsion we are talking about. Am I understanding correctly thatās an hardware issue? Size of icons is almost doble from left to right.
I donāt think this is a hardware issue. The 4 corner correction is purely done in software unlike the vertical keystone correction. Hopefully, this one will be fixed soon. 4 corner correction right now is almost like an anti-feature because itās not working properly and takes a lot from the system performance.
Yes you are correct. That is different to my issue -
Red = Original Pico
Yellow = 2nd Pico
Black = Rectangle
Unless you created a bracket to hold the PPX in the exact same position, which you have securely mounted at the same spot, for both sets of pictures, you canāt compare these pictures. Any offset from the lens plane being perpendicular to the wall will create a distorted non-rectangular picture.
Any progress on the linearity distortion with 4 corner correction?? (not the rectangular image issue some people started talking about)
Any ETA?
Yes, this bug has been fixed and is internally in testing. It will be included in the next software update.
This is fantastic news. Iāll be much more likely to get the projector out if it can better handle a less than ideal off-centre setup.
