Has anyone got the best setting for the U5 and PS5 to support 4K?
My U5 keeps saying the connected device doesn’t support 4K when connected to PS5 via the hdmi cable that came with the console. Somehow my another android tv box can set it up to 2160… Any suggest please?
From a PC, you have a problem if your graphics card does not support 4k output. Not sure if PS5 itself supports 4k? But I also found the U5 does a quite decent job of upscaling HD (1920x1080), so you should be OK at that. Finally, on my PC RTX3060 that does support 4k output I successfully connected by HDMI to U5 at UHD (4k) HOWEVER, I could not get any HDR (extended color space) output to work.
