Hello i can’t install twitch mobile version with apk mirror installer.
When it install the app to the end i’ve the message « app installed failed the new package has an older version code than the currently installed package. But it’s lhe last version of app (14/05)
Pls help me
Have you tried uninstalling twitch mobile first and then installing from apk mirror?
You could try with an earlier version. The one you’re testing is a beta version, isn’t it?
Another user reported success with a Twitch apk downloaded from APKPure. APKPure has its own installer for its bundles, so you need to install that as well if you want to try that.
It’s ok i’ve uninstall twitch app android tv before and now it’s good
