paspao
1
I am using a SR-C30A Soundbar that works well via HDMI/ARC but has audio delay via bluetooth.
I wanted to keep HDMI to use an external source.
Do you have this issue too?
Anyone used a HDMI/ARC splitter to have both soundbar and external source connected to projector?
Thank you.
Ali123
2
Adjust the lip sync or audio delay settings on your TV and/or soundbar.
Other option - Changing the TV’s digital audio output to PCM and disabling features like A/V sync, pass-through, or eARC in your TV’s audio settings.
