Bluetooth headset
I’ve tried to connect 2 bluetooth headset at the same time and it doesn’t works.
I’ve sound only in one headset (Marshall Major II)
When i go on the bluetooth setting it says in one headset : “no streaming audio”.
Do you know why ?
It isn’t possible to have 2 headset at the same time (as you said it ) ??
I believe this is covered here: Using more than one bluetooth speaker
Will be added in a future update
Again another promised functionality which isn’t there…
It is indeed a feature that will be added with a future update. The hardware is there, the software not yet. So currently it is not working.
