Hello fellow projector owners and Philips, my 2 year old son thought it was a smashing idea to play with the remote and when I was trying to take it from him my son thought I was playing with him, one thing led to another and he threw the remote on the floor.
Since then I can’t use the mouse pointer function, the remote is a bit slower and also has limited range compared to before.
I like the projector but my big question is, can I buy a replacement remote? Yes I know it’s my own fault and I’ve had to hide everything from my son but occasionally shit happens and this was one of those times.
Where can I buy a replacement remote for the picopix max?
It sounds like the Bluetooth disconnected. Did you try re pairing the remote?
“ In order to do so, please go to the projector Settings>Bluetooth. On the remote control, press OK**+** Volume- keys for 4 sec until the LED blinks. You should see the Philips AirMote appearing on the projector Bluetooth Device List. Press Connect on the remote control.”
Seriously didn’t you think I would try this? It’s not that at all, it’s severally damaged and not disconnected from
Bluetooth. I can’t use the pointer which is essential when selecting what to watch on Netflix when you can’t the arrows
I don’t use android, my grandmother bought Macintosh way back and since then my whole family and most relatives don’t use anything else except apple products
