Anyone with a suggestion is welcome.
Searching the internet, I found this solution which looks very promising:
I’ve been watching the following item on eBay for a while, but I’m waiting for my PPM to arrive before I buy it!
I’ve got one of these, great quality. They come in black and white.
I bought an Arkon mount:
or this one:
These are also available on Amazon.
This was just $8.76 when I purchased it
Planning my media room at Home around this projector. I still see “No shipment with given tracking number found.” i am getting impatient
Any idea what kind of ceiling mount that i can consider? Does it come with one? Additionally, what is the max length of the USB C cable and power rating? It will be great if someone can point me to the information.
For a portable projector a ceiling mount ? Why?
Should have bought a wired one then …has better resolution.
But if u really want then this is a cheap choice.
Or wait till next month…I’m getting an imported mount for my other projector which I may not need
great. thank you.
I don’t think this will work with the PPM, it’s more for bigger projectors the PPM only has one small 1/4 inch tripod hole on the back centre
Don’t they all have 1/4 inch holes ?
This will work.
https://www.amazon.in/gp/product/B085WZD5F8/ref=ox_sc_act_title_1?smid=A2SSIJ9ZOFEKBC&psc=1
But your example is designed for large projectors with 4 mounting holes same as VESA mounts on the back of a TV, where as the PicoPix and all other mini projectors have only one mounting hole in the centre
Not strictly a cieling mount but works for my living room and offers an alternative location that are not fixed
