Hello, I’d like to hang the Picopix Max on the ceiling … as flat as possible. But I also use it as a mobile device, so I’ve thought about taking a magnetic mount. Can it harm the beamer?
This one:
What you think?
This one:
What you think?
You have a metal ceiling?
You can go with any mount that uses the bolt connector. Just unscrew the projector and take it with you.
I have mine mounted on the ceiling and take it with me for stuff.
The one hassle is that the ir receiver is at such an angle when the device is upside down and pointed down that it can be hard to get the remote to work.
