Hi all,
found some ceiling mounts online but I was wondering
if any of you found one that works with some sort of quick release?
I don’t want to screw the device on and on the ceiling every night to charge it.
Want it to be cable free and only charge it when not watching.
Thanks in advance!
Joris
I have this thing on my ceiling. Works fine. First adjustment is a bit tricky, but okay.
celexon Mini-Beamer-Deckenhalterung Multicel Pico - bis 2 kg - 360º - +/- 15° schwenk/neigbar https://smile.amazon.de/dp/B0154JCVYE/ref=cm_sw_r_cp_api_fabc_lpH-FbVBSJM0N?_encoding=UTF8&psc=1
_fov
3
I use a small quick release intended for camera accessories, in combination with the ballhead from the small tripod that came with the projector.
(cheaper versions of it can be found in amazon et al)
