Hi guys, I updated last firmware and deleted Hulu and prime as I don’t have accounts but aptoide disappeared too!
How to put it back?
Have you tried to Refresh app list from the Settings menu?
Alternatively I believe the APKs can be found in a folder on the PPM, use the File Manager from the Settings menu to re-install Aptoide.
I can’t check right now as the kids are using the PPM
Thx. Didn’t find it, I did a factory reset
Sounds like factory reset fixed it, but you can also get the Aptoide APK and download it to thumb drive or SD card. That’s how I fixed mine after accidentally deleting the Aptoide app.
