Tried the same thing yesterday. Nlziet indeed does not seem to work.
Ziggo Go however gives the same gms error, but when you click ok still continues on my PPX and is usable:)
Videoland also works.
The ziggo issue is due to the lack of GMS, and sadly there is only a small chance that will be fixed. If tmobile is also GMs related it is the same issue. Haven’t tested that
@IvoG , Oh yes, well when I tried the ‘standard’ Disney+ apk, it installed, I could also fill in my credentials, but then the application crashed. I tried to reboot, but still kept crashing, also reinstall didn’t work.
So I googled and found a solution for an other device (Android TV OS running) and I tried that solution and that worked for me:
@IvoGrijt it is an apk installer. ( Split APKs Installer (SAI) )
when you have the 3 apk files, just select them and install them with SAI.
And be patient, let the installer finish all the 3 installations first before starting up Disney+, otherwise Disney+ could have issues.
@yhalmudt yes download them on the ppm itself with browser or put them on usb/sd and install from there. First the SAI app and then open the SAI application and select the 3 files (or the 1 zipfile) and install.
