Hi , i connect the Fir tv Amazon Stick 4K Max to the Screeneo U5.
There is an option to setup the stick remote to manage the volume of the proyector by connecting the stick remote to the proyector.
I select the brand of the “tv” Philips but the fire stick remote not pair with the proyector.
There is a manual option to setup it but they ask for a IR PROFILE NUMBER of the Proyector.
Anyone no which one is ?
Thank you.
I have asked the same question seeing as your’s did not get a reply.
I set it to Code Group 13 in Infrared Options | IR Profile, and it controls the volume properly, you’ll see the TV being set to RCA instead of Phillips though.
HTH
It’s not work for me the number 13
Hi all, if you remove any IR profile, the Fire TV remote should fall back to CEC commands. This should work perfectly for controlling the volume or turning the projector on/off.
