I connect the PS5 to the video projector and cannot activate HDR with the last firmware (1.6.7), I have a message saying that the device does not support it.
I tested both of HDMI with the same message.
The HDMI cable used is the one given by Sony with the PS5.
But with the first firmware, the HDR worked because I had to adjust the hdr settings on the PS5.
To get HDR10 working on my alexa fire tv with firmware 1.6.6 i had to use bluetooth audio output. With ARC enabled, it was not detected. Iām using HDMI 2.1 cables.
Please try setting sound output to ARC and then back to internal speaker, AUX or Bluetooth.
Explanation: When ARC is enabled, HDR is disabled because HDMI is dropped down to V1.4 for technical reasons. Itās possible that after the software upgrade, the HDMI EDID value became stale or corrupted. Setting sound output to ARC and back to internal speaker will cycle the HDMI EDID from v1.4 to v2.0 and might clear out any stale or corrupt settings.
I got the same issue. If I run Google TV (4k Chromecast) it supports 4k and also HDR, but with the PS5 it says the TV doesnāt support neither HDR nor 4k.
Tried connecting directly in both HDMI ports and toggled audio output.
PS4 Pro⦠and issue here⦠4k Firestick works no issue with HDR and 4K upscaling. PS4 Pro say āTV not HDRā and Iāve gone through messing with ARC etc⦠what now⦠?
Are you planning to fix this issue in next software release?
If not, then customers should be clearly informed e.x. āHDR10 support* (*not available with ARC)ā.
i told them for the windows incompatibility months ago they said itās not normal
With the first firmwares i used to work
and indeed, HDR with androidTV (the only one i can make it work) does not work with ARC. Thatās clearly something that should be changed, itās a shame to have such small but annoying issues
