Audible hum/buzzing when both headphones and charger are both connected. Obviously quite annoying.
Buzzing goes away when usb-c charger is unplugged. Is this due to poor shielding?
How do I fix this…?
How do I fix this…?
4 posts were merged into an existing topic: Buzz noise when not using lowest brightness settings
Hey dude, I think your problem can be solved with a ground loop isolator. $10—20 on Amazon.
