How does this button on the remote works?
Hello , you can use it when APP is compatible. Then you can see a blue circle and deplace it with the arrow direction of the remote
Press once to activate the mouse cursor then press again to simulate a click like a mouse.
You can also use it like a touch for apps that are more designed for touchscreen. Like for example, click and hold on a blank surface and drag to scroll contents.
Press any of the arrow buttons to hide the cursor.
It works only after you paired your Airmote, see pairing airmote
Does the Airmote have a gyro for the mouse cursor or do you move it around using the arrow keys?
It has gyro or whatever sensor that is. It works like LG’s remote.
Hi @Andrej_Mioc it’s not clear from your picture which button you mean, can you point it out?
Please see this post for more info: How to pair the AirMote?
Thanks.
