If your PicoPix Max cannot start to the Home Screen, you may need to perform a factory reset to recover it. Here’s how.
Warning: all your apps and settings will be erased. However, the latest software update you applied, and the preloaded apps will stay.
How to do a Recovery Factory Reset
- Power off the projector
- Insert a pin or SIM eject tool in the Reset hole (see picture below), till you feel the reset button press.
- Keep it pressed and press-and-hold the power button to start the projector in Recovery mode.
- Once it starts in recovery mode, use the remote control to select “Wipe data/factory reset” option.
- After the reset is completed, reboot the projector.
If this procedure doesn’t help, proceed to do a full cable restore.
