Hi. Is there something I need to do to get the internal speaker to work. I can get the sound to work no issues via Bluetooth. I’ve tried multiple apps and all the same.
But when I try the same apps with the internal speaker nothing happens.
It should just work if you turn up the volume.
What does the volume icon on the screen show when you turn the volume up? Might give an idea if the speaker is dead or the volume control is not working
Just to narrow things down a bit… do you hear anything if you plug in a headphone into the 3,5mm jack on the back (do so with a low volume at first and only increase the volume gradually).
This will help narrow down which audio pathways are working and which aren’t. You’ve already established that the BT route is working, now we need to know if the internal audio is broken or if the speaker (connection) is broken (or severed / loose)
It’s a silly question, but are you sure the bluetooth speaker is disconnected ?
It behaves as if it flows the sound through the bluetooth speaker and therefore doesn’t through the embedded one…
Bonjours à tous.
Je viens de recevoir mon picopix Max Il est super Mais voilà quand je regarde un film il n’y a pas de son
J’ai voulu le mettre à jours. Il télécharge la nouvelle version mais a 99% il me dit erreur
Donc je ne peux pas le mettre à jours.
Que dois je faire. Merci
Tu peux le mettre à jour hors ligne (update téléchargé sur une clé USB)
Tuto ici :
Pour le son : quelle est ta source de lecture ? directement le PPM ou un lecteur connecté via HDMI ?
Recherche un minimum dans le forum et je suis sur que tu trouveras des réponses à tes questions
A++
I am amazed that the sound in ac3 is not taken into account by the picopix Max while my old model pp4935 takes it. is there a way to read them. thank you
Just found the 3rd problem with my ppm.
When it is connected to my laptop via HDMI, there is not sound.
I can her a “beep” and then nothing.
Tried to replace the cable, tried to restart the ppm and the laptop, sometimes it is working and sometimes not.
I’m just tired of all those issues, and now i need to wait for a replacement.
Sigh😩
