Is horizontal keystone possible or coming in a future update? I don’t mean auto. Just manual? Or even presets? I think this would be a VERY important feature for a lot of people seeing as four corner correction does fix the stretched perspective issues. Any info?
Linearity correction is on the list according to:
Manual H keystone correction (for internal sources) can be implemented using 4-corner, that should be simple enough to implement but it doesn’t seem to be there (yet).
Hello!
I’m looking to use my ppm via Hdmi or USB-C, do they have horizontal or vertical correction?
Only vertical correction is available on external sources and only auto at the moment.
