Manual Keystone seems to be resetting every reboot. Is there a way to save the setting permanently or any fix expected in upcoming days.
Mine as well, seem to be a bug
Yeah, am memory function would be nice.
Same here, after restarting it is reset.
Anyone know where I can find a list of known issues and plans for fixing them?
Same here. @Philips_Support_P could you please confirm if this is in list of bugs to be fixed?
Same problem for me - I have latest firmware.
glad to hear this wasnât just for me. was getting a bit frustrated by it resetting after power off. i have mine setup in same position for a while so was hoping it would keep settings.
+1 here.
reset on every reboot⌠itâs a little bit annoyingâŚ
Hello people,
I need help!
I got my recent PicoPix Max, everything works.
But it just doesn´t save my trapeze settings.
I have the current version installed.
All the time, I turn it off, turn it back on, I need to set the trapeze settings, which is soooo annoying !
And the other thing, which really is a pain in ⌠sometimes the remote just doesnt work as well. Just to turn it on, and than no volume control, no âgetting back to the menuâ etc. ⌠after turning off, turning on the device 2-3 times, than it works (sometimes need more restarts) âŚ
Any advice you guys can give me ? Thank you !!
Greets from Germany
Hello guys, same problem here. Seems like a simple issue, why is it not fixed yet?
Same issue, vertical keystone settings is lost at every restart
Hi @chaosgrid, it is a bug that we will fix asap.
It seems like it will never be fixed
Is there any update on this? Itâs getting quite frustrating having to re-do all the keystone settings every time I turn on the projector. I have my projector in the same position so if it could save the settings that would save a lot of time having to re-do this every time.
Hello @jashraf this bug has been fixed and will be available in the next software update.
When is the next Software release coming up?
Hi @adityamishra we donât have a specific date but itâll be within the next 7-10 days. The internal version has some problems which we are fixing. Then our beta testers will test it for a couple of days before we release.
Thanks !
