Hello everyone
I am just wondering if someone has worked out what the largest capacity SD card can be used with the PPM for ‘on-the-go’ projection? I believe that 128Gb has been suggested, but also that it could be more.
Thank you!
Andrew
Hello everyone
Thank you!
Andrew
I have a used a 128gb as well. I do not have a higher capacity.
… Thank you for letting me know.
Best wishes
Andrew
… That’s great – this capacity would be amazingly useful. Thank you for your help, and sharing the information!
Andrew
Bumping old thread with subquestion - what filesystem should be used on such big card? Not FAT32 I believe. So: NTFS, exFAT, or maybe any Linux partition (eg. ext4)?
ExFat
