my projector runs fine, but it always shuts down after approx. 90 minutes of usage without any message - the image just turns black. The accu is not empty yet, its around 50%. It also happens if plugged in. Could you please advise? Is this a software bug? I installed the newest firmware, same behavior.
Thanks,
Patrick
Hi Patrick, welcome to the forum!
Please answer a few questions for me:
- Is it hot to the touch when this happens?
- What are you doing, is it always the same app?
- Is there any message saying “Shutting down…” or something along these lines?
- If you put it on right after it shut itself off, does it come on?
- Check the following: Power - Timed Shutdown. What do you see there?
Hi Ivo,
thanks for the quick reply. Please see my comments below:
- No, not really hot, but warm - but not more than a projector is when used
- It happens as well with amazon video and netflix as with the integrated video player
- No message at all, it just powers off
- Yes, it comes on after shutdown
- No configration set with timed shutdown
Thanks again!
I am an IT Architect and Software Developer, so quite a bit
Excellent! I’ll need you to grab some logfiles from the device to enable us to troubleshoot what’s causing the shutdown.
Sure, how exactly can I download those from the device? Is there a debug or developer menu or similar?
Check your PM’s (not to be confused with Check your PMS
