Hi All,
I have a Philips Picopix Max One projector and I’m quite happy with it. However I couldn’t find an option to use my Nintendo Switch via type c port and cable. I can use hdmi dock but one usb c cable solution is better than a dock and cable salat.
I saw the topic in Picopix Max session; a user succeeded to use Nintendo Switch with type c cable to his Picopix Max projector. So I think, it shold work with Picopix Max One too.
I used different type c cables which I know thay theye are not only for power cables. I’m using them with my mobile type c monitor with my Nintendo Switch or Huawei P40 Pro phone projection.
I updated projector’s firmware. Nothing changed.
So, where is the problem on Philips Picopix Max One?
Thanks in advance.
