No sound via bluetooth when using firestick
Does anyone know how to get the sound to a bluetooth speaker when using firestick via hdmi
Works fine otherwise
Can you pair your bluetooth speaker directly to the Firestick? That’s the only way, because you cannot output sound via bluetooth from the projector while using external sources. See this thread: INFO: Limitations of features for HDMI and USB-C inputs
Sadly not but thanks for the link. Looks like I’ll have to try putting a bluetooth transmitter into the audio jack
Hi @Vincentsuperdude why can’t you pair your speakers to the FireTV directly? This is the setup I use and it works perfectly.
Didnt know that was a thing but works perfectly. Thanks
