I have been using PicoPix Max for over a year, and one problem troubles me. The brightness output of my projector is really weak. I thought that some update might solve it, but it seems that It is a hardware problem.
Reviews from other users show and mention that the brightness is excellent, but my si weak compare to them.
I attached photos captured during dark autumn cloudy days. Even though the projection is not big (you can compare it with the size of the guitar), the output is dim.
Even more disturbing is that I used to have my old projector Optoma ML330, which claimed 500 ANSI lumens, and it was even brighter than my PicoPic Max with 850 ANSI lumens. The attached picture clearly shows (besides the different colour profiles) that the PicoPic Max is dimmer even though it should be 70% brighter. The picture was taken in a completely dark room.
Just a reminder, all pictures were taken when the projector was connected to power and was in either presentation or normal mode.
Despite the claimed high brightness, this is a really poor outcome. It almost looks like I have PPX620 with the PPX520 light source. The projector was delivered to me with a long delay, and the reason was the lack of a light source, which only one manufacturer supplied. Should this be the result after all?
I have once complained about the projector due to a faulty battery charge. Even this complaint did not improve the light output, which I already mentioned at the time.
Does anyone have a similar problem? Do you know what it could be?
Thank you in advance for your reply.
Ondrej
