Hi. is anybody using the V2 Launcher willing to help out?
I was running my PPM fine until I changed the setting to projector mode and everything went dark… I now need to blindly go back and select ‘Normal’ or ‘Eco’ under Image settings but can’t remember the number of steps/clicks needed. Hopefully somebody can send screenshots of the Left Menu popup, and under the Image menu… thanks a lot!!
This is solved. I was able to restore to factory and start over.
