hello
first of all, thank a lot for this forum and for the hard-working you have been putting on it.
I have been using my PPM since more than 2 months without any issue.
It was perfect and smooth.
Tonight i was using my ppm watching Netflix with Amazon with Fire Stick.
The PPM was plugged to this own charger and suddenly it just turn off and the led was red and blue.
Now if i try to turn it on, the led gets blue, the fan works normally but the but the light stays off
Is there something i can do?
thank you
