PPX620 Fell from desk, Verticle lines, No display after reboot
I’ve been enjoying this projector for a few years,
and have fired it up on a sick day to watch some movies.
I managed to knock the unit off a desk onto carpet flooring which made the image have around 4-5 thick red/pink vertical lines.
After rebooting it, there’s no image being shown.
The unit powers on, fans work, and the auto-focus does engage when moved.
Since purchasing this in 2019, I understand i’m far past warranty.
Is there a fix anyone knows of? or a part I have to replace?
Thank you.
Edit: I took apart the unit, but havent found any loose connections.
Im unable to disassemble more, as a plate is riveted above the lens.
Anyone have any tutorials to look deeper?
Here are some things you can try:
  • Check for loose connections
  • Try a different input source
  • Consult a repair service
