After my initial disappointment with the internet connection issue I was happy to report that my unit was functioning fully. Now it seems that my remote control does not communicate with the device. Is there any suggestion on how to make these two reunite?
Have you already paired it via bluetooth? otherwise it’s just using IR which will only work if you point it the back of the projector or bounce off a wall.
Press and hold OK and Volume down on the remote until the LED blinks.
In the projector’s bluetooth settings, looks for the Airmote and pair it.
Sorry to say but OK + VOL DOWN is not working… I can shut off the device with the remote but I can’t get the pointer working… I do see other bluetooth devices in the list
Please make sure to follow ALL the steps mentioned here: How to pair the AirMote – Philips Projection
5 posts were merged into an existing topic: Bluetooth is not working
