Would it be possible to make the battery low voltage level in the android smart tv remote control selectable. I use rechargable batteries as opposed to rechargeable. They operate at a slight lower voltage per cell so the and the warning message comes up a lot when the remote probably would last a while longer. Alternatively perhaps you could just flash a code on the remotes led as opposed to the on screen low battery message popup?
