Samsung Wireless Dex Compatibility
Trying to connect a Wireless Dex Enabled Samsung Galaxy phone yields an unusable image, although the connection is there to a degree, one can see icons, but distorted. It seems that the signal is imperfect. Maybe this could be cleared up? It may not be a feature, but an update on wireless connections.
Having the same issue with a Note 10 plus phone. No fixes yet… And I am not the only one. One coleague of mine has exactly the same issue with his phone and projector. It seems wireless dex will only work with tv*s from Samsung newer than 2019.
I can’t get dex to work even with samsung dex cable (usc-c to HDMI). My phone is s10+
Does it work for you? Any tips?
