Hi everyone,
I’m facing this difficulty while using the PPM: I’m unable to reconnect to the PPM without either restarting my comp (surface book) or PPM.
Wondering if anyone is facing the same problem and/or has a workaround. Thanks!
Klay
Hi everyone,
Klay
Got similar issue but restarting my iPad doesn’t work. I must restart my PPM in order to get the mirroring reconnected…
I think this is a bug.
we will check this @Philips_Support_P
Any update on this, please?
Mine is resolved HERE
Since mine is due to an issue on my MacBook as other backers do not face similar issue. I can also do it with my iPad.
6 posts were split to a new topic: Screen mirroring problem with Samsung S9
