I want to install Netflix in my Screeneo HDP1690
Plz tell me how to
Do it
Thanx
Plz tell me how to
Do it
Thanx
Download the Netflix APK file and put it on a USB stick or a memory card. Then you can install it according to the instructions on page 35 in this manual: https://www.download.p4c.philips.com/files/h/hdp1690_eu/hdp1690_eu_dfu_eng.pdf
Disclaimer: I don’t own a HDP1690 myself and have never used one, let alone tried installing Netflix on it. The tips above are only what a little googling came up with.
By the way, this forum is for the PicoPix Max projector, so you’re likely not going to get much help with the HDP1690 here.
