I’m looking for a link to update my firmware on my screeneo S4. (my version 1.0.31); when i try with online update i have an issue “verify network” but all is ok (i can go on netflix/aptoid and download apps).
So i’m looking for a way to manual update but this firmware seems rarer than the grail itself.
Thank you for your help; if it’s a duplicate post please give me the link to the post to download the lastest firmware.
Hello @Philips_Support_P Is it impossible for you to give a download link for firmware 1.0.31?
You sell these video projector with this firmware …
Otherwise can I try the firmware of the jmgo N7 because it is a bit their technology inside?
1000€ to put it in the trash …
Next time I would buy Chinese directly (at least on their site we can find the original firmware).
My screeneo had no problem in 1.0.31 but it was very limited at the interface and that is why I updated the firmware.
So I would have to pay for a repair when I just installed a firmware from you…
What is sure is that I will not take products from you.
