Hello, can you tell me witch type of 3D glasses must be used to watch 3D movies with the Screeneo U5 ?
Hello, you need to use 3D DLP Link with multi frequency rates.
Does your projector display a black bar that moves from bottom to top repeatedly rendering 3D option useless?
The black bar is happening to me consistently when screening ‘sider-by-side’ 3D (e.g., streaming from VUDU), but not when setting to frame packing 3D (e.g., playing a 3D Blu Ray).
I’m using “Ultimate 3D Heaven-DLP link” glasses with my Screeneo U5 , which are excellent. (Used the same brand previously with a Sharp projector). https://www.amazon.com/gp/product/B00S8S26TE/
Thanks a lot
